Steering Shaft Length?
moparspares
Scarborough, Qld
Does anybody know the correct length of a 73 Duster Steering Shaft. I have mine disassembled. I can see the plastic shear pins but I suspect that it is collapsed. It's current measurement is 38 1/4 inches and from what I have seen on a post on the net they are supposed to be 41 inches. Can anyone confirm this. It has power steering.
Manual steering shaft is ~40-5/8"
Power steering shaft is ~37.5"
Those are end to end measurements without the couplers attached. Keep in mind the coupler slides back and forth as well.
38 1/4" is about right for a power steering shaft if the coupler is in the shortened position. If it's not then the steering shaft may be partially collapsed.
I pulled it out to correct position and got 37 3/4" so yes it was partially collapsed. Thanks for your help.
are these the same for my 69 dart
looking to see if the extra steering shaft i have is power or manual
so pull the wheel and slip joint and then i'll know for sure
