Steering wheel grinding noise.
Mopar Interiors
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    522
    125
    May 18, 2019
    Indio California
    Local Time:
    2:08 PM
    I have been getting this steering wheel screech/grind noise ever since I changed my Ignition cylinder, Everything went back on like it cam off. So I decided to change the small bearing and it is still making the noise. Does anyone know what other component could be causing this?
    Thanks
    Here is a link to the video I made seems to happen more when I turn the wheel to the left.
  2. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    20,987
    8308
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    4:08 PM
    Sounds like the horn slip-ring, or the steering wheel itself.
  3. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    6,577
    4346
    Jul 16, 2017
    Northern Colorado
    Local Time:
    3:08 PM
    Just tell people your screeching the tires:rofl:
    Sorry no help.
    • Like Like x 1
    • C2ndLTpigeon
      522
      125
      May 18, 2019
      Indio California
      Local Time:
      2:08 PM
      Can't be, I removed the Horn and steering wheel this morning and barely attached it to the splines so I can turn the wheel, it is defiantly not the wheel.
    • 67dartgtgo
      67dartgtgo FABO Gold Member FABO Gold Member
      1,415
      856
      Nov 9, 2012
      Mass
      Local Time:
      4:08 PM
      I had this happen once when I reinstalled my column. After lining up the steering shaft with the coupling and moving things around to get them aligned on the box tightened in place....by myself....I somehow caused the upper bearing column snap ring to pop off. This caused a misalignment and my wheel was able to be slid up and down a slight amount...about an eighth of an inch or so and it was rubbing on the outer column. I knew something was wrong right away and broke it down from the wheel. Found the snap ring had popped right off.
      I also had a horn ring contact that had spun a quarter turn on another car and after it had worn the contact wheel clean in half, that’s when it started to make noise with a slight movement of the steering wheel.
      Good luck.
    • C2ndLTpigeon
      522
      125
      May 18, 2019
      Indio California
      Local Time:
      2:08 PM
      Ill try dismantling it tomorrow. When I reinstalled it the bearing went down far enough and the snap ring is on there. Just trying to see what else I should look for?
    • BobW
      BobW Curmudgeon At Large FABO Gold Member
      398
      256
      Jun 26, 2020
      Central, FL 34705
      Local Time:
      5:08 PM
      Is the new cylinder longer than the one you removed, possibly contacting the steering shaft?
    • TrailBeast
      TrailBeast AKA Mopars4us on Youtube
      21,710
      9538
      Mar 11, 2011
      Arizona
      Local Time:
      2:08 PM
      It is common for the graphite button that contacts the horn ring to have dried up gunk on it and make a screeching sound.
      Try cleaning the ring and button, then a light lube.
      I use white lithium grease on those. (Just a thin film)
    • eekvonzipper
      eekvonzipper My Member is Legendary! FABO Gold Member
      561
      421
      Apr 18, 2020
      Cadet, Missouri
      Local Time:
      4:08 PM
      Mine used to make that sound...
      I did a Bearing, Blinker Switch and a Horn Kit.
    • C2ndLTpigeon
      522
      125
      May 18, 2019
      Indio California
      Local Time:
      2:08 PM
      Looks like all it needed was done grease on the underside of the steering wheel. The screeching looks to be gone. Thanks for the tips.
