Steps Prior to 340 Engine Install
ADHD426
CA
I have a 71 Duster. The engine compartment is bare apart from the K-member, and the front suspension is all new. Is there anything that I should install, that would be easier to do, before bolting the engine to the K-member? I have TTI headers, should I put those on before putting the engine in? Any and all thoughts appreciated. Thanks!
Andrew
Sounds like you're dropping it in from the top, so-
Put the headers in the engine compartment before lowering the engine in. Mount the starter before bolting the headers up to the engine.
And maybe leave the distributor out (or at least the cap) until the engine is in.
I would suggest putting everything on the fire wall like the brake lines and wiper motor and the master cylinder. Its easier now, you wont have to reach over the 340...Good luck with your build....Rich
I always like to use the opportunity to clean while the engine is out. I hate it when I see a brand new shiny engine in a crappy engine compartment. Think diamond in a goat's butt.
