[Found!] Still looking for a set of 360 main caps
Dumb question time. I have a set off a 273 that I won't need, would they work on your 360?
Thanks for the plug Demonracer. I have reached out to 440BelII in the past on this.
The 273 caps will not work for a 360 given the 273’s smaller journal diameter (2.5” versus the 360’s 2.81) and wider bolt spacing.
Can you just bolt on a non matched set of caps? I think you might need to plane and bore in which case finding another block may be cheaper.
Halfafish, thanks for the reply. Rocket is correct. They won't work on the 360. I have a set from a 340 but they don't help me.
Sent you a pm a couple weeks ago, I’d be interested in your 340 main caps if your interested in getting rid of them.
