As the title says how many of you have sprayed motors with a well build stock block. I have a 420" 340 based internally ballanced small block. It has a 4340 BPE crank with bcr steel caps and the block is filled. Im guessing the motor makes around 550-575hp on motor. What combo's have you sprayed on a stock block?
