Stock cast iron intake height 2 brl-4brl ?
rustytoolss
Clinton, Ohio
I dont have any intakes to measure. But can anyone tell the height of stock cast iron dual plane intakes stock 2brl...and stock 4brl. small block engines.
So if the intake was sitting on its heat riser heat shield from the table to the flat the carb sits on?
OEM 4 BBL 67 273.
2536771
The heat riser rivets adds a little to the dimension IF it was on a hard flat surface BUT on the Recycle bin the lid deformed and BOTH front and back were flush on the lid at the same time.
2 7/8 front
3 7/8 rear
