carfreak6970
It has come to the fun part engine work on the car I'm working on. It is an original 383 4 speed with a 3.23 Suregrip in the 741 case but the engine is out of a 70 Polara. The engine is the 2 barrel version and according to the data books it has an 8.7 C.R.
What I would like to do is set this motor up as a street motor that may see the track once in a blue moon (being honest here). It will be used as a fun cruiser with stop light brawls and hard pulls in and on the high way. I would be keeping the 3.23 in the rear with maybe switching to 3.55 a couple years away. I will be running a stock iron 4 barrel intake with an AVS or maybe a Holly. I am going to be running either the TTI or Schumacher (didnt decide which yet) headers. I would like to build this engine pretty close to the 68 version with a little bit of a hotter cam. Right now the engine is the stock bore but will probably need to be bored out. I will be running the stock valve train as well.
I would like to run around a 10 to 1 CR and have some good low and mid range power, but still has a little top end. Sadly I dont know much about the heads as I didnt measure the chambers, but I am fairly certain the heads I sent to the machine shop are the ones that came on the engine originally. However, what pistons should get me to my goal?
As for cam selection I did some searching here and found a few ideas, and went on COMPS website and found a couple more. I am going with a hydraulic flat tappet cam. Of the following cams, which would help me reach my goal of a great street motor that has a distinguishable idle and makes good all around power?
21-406-4
21-600-5
21-670-4
21-306-4
21-237-4
21-225-4
21-305-4
Would anyone have any other suggestions that I may have missed? I obviously want to make as much power as possible, but this is going to be a street motor. With what I am working with here, what kind of horsepower and torque numbers can I expect from a build like this?
21-406-4
21-600-5
21-670-4
21-306-4
21-237-4
21-225-4
21-305-4
