Stop in for a cup of coffee
Pulled the pan
I give up
Not running you will lose your shirt.
You are already in up to your neck. I've been there a few times. Driving season is almost over. Time for a 3 pedal conversion.
I have a push button delete plate I've been saving for you.
Gotta cut it off. I'll lose about 15k but it has to go. It's making me insane
There will be a deal on a 97 F350 7.3 dually as well.
Let me talk to my friend on Monday. . Working on those pictures and info we talked about.
Gotcha... Working the write up now....
P.S> This is NOT a sale ad... It's just me being VERY FU---ing ANGRY
Work that has been done:
Underbody and wheel wells have been completely stripped of the old undercoating and painted with Eastwood Rust Encapsulator
Frame rails have been cleaned out and painted inside with Eastwood frame paint
Body work was done some time back; all badging and trim were removed except for the top of the rear quarters. Exterior body color is not year- correct WW1 but is a bright white.
NO RUST
Engine bay stripped, epoxy primed and painted to WW1 before new engine and headlamp wiring harness were installed.
Engine
273 LA motor built by Valley Motorsports in Michigan – Spec sheet in photos. Built to emulate a Commando 273 Valley Performance & Machine Service
1964 Block with 1967 heads (so accepts modern intakes)
10:1 Pistons
Edelbrock LD4B aluminum intake
Holley 4160 4bbl Carb
Electronic Ignition
Distributor was built by Halifax Hops and curved for this motor.
Aluminum, 3 core Radiator
All new hoses and belts
Transmission - DOES NOT WORK
1964 A904 pushbutton transmission
Correct 1964 Valve body
New Shifter Cable from MOPAR MALL
New Park Cable from MOPAR MALL
Dex Merc fluid
Torque Converter built by Biltron Biltron Quality Automotive Remanufacturer
Ball and Trunnion rebuilt on prop shaft
New rear U-joint
7.25 Sure Grip rear with 3.91 gears
New Mechanical
Fuel Tank
Fuel Sending unit
Fuel Lines (Inline Tube)
Brake Cylinders
Brake Lines (Inline Tube)
Front disc brake conversion
Disc/drum master cylinder
DOT 5 Brake fluid since restoration
Proportionating valve
New Emergency brake cables
Rear drum brakes rebuilt
New KYB shocks all around
K-member replaced with FirmFeel reinforcement plates
Lower control arms restored and reinforcement plates welded
V8 Torsion bars
Front suspension rebuilt with OE rubber and Moog components (ball joints, control rod bushings, etc)
New Engine mounts
Electrical
H&M Engine Harness
H&M Dash Harness
Body harness remains original
LED Headlights
Interior
Interior stripped down to the floorboards
Welded patches on drivers' side and behind the rear seats
Entire floor painted with Eastwood Platinum Encapsulator
Sound deadener applied to all floor areas
New loop Carpet installed
Seats have had springs and frames cleaned and painted
Rusted portions of rear seat frame have had new steel welded in
New Seat Foam
All new vinyl seat covers by local upholstery shop
New chrome dash bezels
Gauges with red/white faces
Exhaust
TTI 2 ½" H-pipe dual exhaust from manifolds (No headers)
Flowmaster Mufflers
TTI chrome exhaust tips
All new exhaust hangers
Transmission cross member modified in accordance with TTI template for dual exhaust
Wheels and tires
Cragar 15 x 6, direct drill Small Bolt Pattern (5x4) wheels
B.F. Goodrich Radial T/A tires (from Tire Rack) with less than 100 miles on them
Power convertible top, works well
No holes in the top, although a bit discolored
Rear plastic window is clear
Seat belts are original to the car
Radio does not work/no antenna
Speaker was torn and has been removed
Defrost hoses are not in the car, but I have them as well as the speaker frame
Many other items that can accompany the car including sales literature, Parts books, TSM, dealership materials and magazine articles from the period, both for the U.S. model and for this (Canadian) version.
I have V8 badges, Valiant nose badge and the rear quarter louvers that were for the 64 Canadian Valiant Signet (not on the car). I DO NOT have any of the body side molding chrome nor do I have the Signet 200 script badges for the front quarters
Talked to the shop owner that sent me that NOS A-12 dist. Yup his customer got screwed badly for sure. Took it apart again and documented what was wrong or not right, Wow there was alot.
