Street Demon accelerator pump nozzles
qkcuda
Jarvis, Ontario
Does anybody know if a standard Holley accelerator pump nozzle (shooter) will fit a Street Demon carb? I looked up a picture and the register looks the same.
I called technical support for my Demon carb with the model number (perhaps serial too) and they told me which Holley was identical. If I remember correctly it was age dependent, i.e., after the acquisition of Demon at some point only the names were different. I think the number they needed was stamped on the top rear if I recall.
I agree that they should work. I believe they had that "anti-pullover" nozzle design originally on the early Holly Spreadbores. The design is suppose to keep fuel from being siphoned out of the squirters at high rpm. BUT, I thought that was the purpose of the needle that were located under the squirters. I suppose they had some design changes that replaced the needle or needed additional help. Don't know at what point if using the standard squirters might cause a problem with siphoning.
Thanks, I have quite a collection of Holley parts. I think I have some of the anti pullover squirters. I will have to check
