one of the 2 threaded holes in the rear frame where the leaf spring bracket bolts onto is stripped. how do I fix this? its not open enough rearward of the hole to get a nut on a bolt
When I relocated the springs in my '68 dart, I moved those rear hanger inward which required drilling one extra hole on each side. I just cut a hole in the bottom of the frame just large enough to slide a wrench with a nut taped to it and ran a bolt through the front. Hope that makes sense.
