Stripping Paint etc...
HotLines
Realist - Free Thinker
southern Oregon
Hello, I would like to know which paint stripper is fastest using it panel to panel?
Also would like to know who sells the windshield and back window rubber gaskets for a 1965 Plymouth Signet.
Also would like to touch base with Charlie S. who sells the convertor thingie to attach a 318 Magnum engine to an early 904 trans..
Thanks in advance :)
Front windshield gasket pn: VWS2702 http://www.vansauto.com/windshieldseals.html
Rear backlight gasket http://www.justmopar.com/store.php?crn=326
There are other sources, but the pricing looks pretty good here. X2 on the aircraft stripper. Wear rubber gloves for chemical handling, long sleeves, ventilated shop. This stuff removes paint, body filler, whatever and will burn your skin badly if you get it on you. Brush on, scrape off and use steel wool to finish. Wash panels thoroughly and sand with 220/320 for primer prep.
Thank you so much for the links to the glass gaskets, 4spdcuda66
68383GTS, as far as the stripper, I know there is something better out there yet thank you for your reply..
