OK finally going back together on the stroker 416 340 today. About darn time... :headbang:
A few question of what others are doing. Here is what I have.
Eagle 4" forger crank and H rods with forged Ross .030 over pistons. Using clevite fully groved mains. So with the cam, head work modifactons etc. , it specs out to about a 535-550 HP engine. Block web looks much thicker than most 314-340s, but is not a TA block, so I did not go with a 4 bolt main kit, felt it was not needed at this level and would weaken the block.
So... :lurk:
1. Should I use better than stock main bolts? Current bolts do look fine.
2. What are you guys with this setup ending with for main bearing and rod bearing clearances?
3. Is the spec on these rods with the ARP bolts 75 ft lbs? That is what I was told. The socket size is a 12 point and i think these are 7/16 size bolts in the rods, not the standard cap screw type. The head of the bolt says " ARp Eagle 1.6 8740 .
If it is 70 + lbs I feel a standard 12 point snapon socket is iffy, will flex or crack and not give an accurate reading. I did order a set of thin wall 12 point snapon impact sockets. That was the best I could find. Most HD applications are 6 bolt sockets and heads... So this is new to me.
thanks guys!
So... :lurk:
thanks guys!
