So I got it out and got it back in both passenger and driver side. I did passenger side first. When I wrench the nut in with 45ft. lbs with the new torque wrench. I kept on wrenching without hearing any click. I realize that I over torque due to defective torque wrench. I exchanged the wrench. Loose up over torque nut and front bushing and re-tighten with 45ft. lbs but I end up with the same thread distant as it is over torque. If I compare driver side with passenger side, There is more thread exposed on the passenger side than driver side. So what will happen if I over torque the driver side as well to make both side balance? (recommend or Not)
Thanks,
Scamp
