olddman
I have torn down the front end of my 1965 Dodge Dart to replace the upper control arm and the lower control arm bushings, ball joints, and tie rod ends. Was going to change the strut rod bushings, but it looks like they are one piece, not two piece. Can someone tell me what to do!! Do I try to find one piece bushings or do I use two piece? If I need to use the one piece bushing, where can I get them. Have ordered Moog two piece bushings.
Also, how do I get them out? If I use the two piece one is there a bushing
that goes throuh the hole in the K-member for the strut rod to pass through to prevent it from rubbing on the K-member?
