Stupid question, but I'm still asking
gunbunny
Cincinnati, OH
Would it hurt anything if I paint the potting on the back of an ECU? Will it cause heat issues if I do? Will help to retain the potting if it decides to leave the ECU?
Will it even stick?
I always thought the heat was dissipated through the top where the heat sinks are. I think if you decide to paint it, I would maybe go with something like a vinyl and fabric paint so it will flex. That said I don't really see the need unless it's something you just want to do.
I've had several ECU's 'bleed' and hate it. Don't know what to do about it....except to paint more epoxy sealer on the back side and doubt that will fix anything.
Will it even stick?
Depends on the paint, there's no need to, & it's doubtful it'll save it if it is in an enviroment that would cause it to "leave". The potting protects the electronics from the environment & vibrations, not heat nor does it particularly dissipate it, the heat sink for the transistor & metal housing are the only things doing any heat-dissipation.
My ShelbyZ sat outdoors for years, & stayed sealed well even with the T-tops,.....and then it didn't. As soon as that occured, and it being black, I jumped in it to start it that summer & My right heel stuck to the floor.
The heat & moisture melted(steamed) almost all of the potting out of the pop-up headlamp module, less than a year later, it quit functioning. Took a little over 30yrs. for that to happen, & wouldn't have if it hadn't been left in those conditions. I'm pretty certain a little bit of paint would not have saved it. JMO.
A lot of people (even the factory) make the mistake of mounting the ECU so it's basically flush with whatever it's mounted on. Firewall, inner fender, whatever. I always put some sort of spacers under them so they get full airflow. Does it help? Crapped if I know, but it sounds good.
I gotta ask, and RRR touched on it; why do you want to paint the back of it?
The current ECU is "melting" the potting off the back of it. We've had some pretty hot days this summer and I can only guess that's what caused it.
It's going to be a bear to clean that potting off of the inner fender. I figure it isn't coming off without a heat gun and a gasket scraper.
I'd really like to not have to do this again when the new one does the same thing.
I was thinking maybe painting it mat stabilize the potting.
I do like @RustyRatRod suggestion. Maybe I can place a couple of washers behind on the screws to space it away from the inner fender.
Something else to consider. Relocate the ECU to the interior of the car. A good place is on the toe board on the passenger's side. Get it totally out of the way of the under hood heat. Mine is on the passenger's side inner fender in the corner right at the firewall. However, it sees no exhaust heat at all, since the intake and exhaust manifolds are both on the driver's side on a slant 6.
They make spacer brackets for the ecu`s.
The 72 NYer were factory.
I don't recall where mine came from:
Making one like it would not be that difficult.
Try a steamer & plastic spreader/scraper, maybe get most of the rest out of module. You can purchase new potting material, pour it & start anew, just a thought. Spacing not a bad call at all if it's getting that warm in it's location.
I didn't realize there's an issue with melting. I guess I'll space mine out before I paint the engine compartment.
I like Halifaxhops idea of re-doing the potting. Then, it would be as Ma Mopar intended. As you probably know he's (she's?) one of the go-to guys around here for things electrical.
Hmmm, all of a sudden my "Quote Reply" and "like, thanks and agree" buttons don't work. Worked a few minutes ago.
Anyway, I've made spacers out of tubing or pipe, too.
EDIT: Now I see that the post I was replying to is gone. I believe it was by @A56. He mentioned using washers to space it out.
Lol, post#14..?....and Your 'Like' showed up in Hoppy's post for Me, yes He's got it going on for ign./electrical..
Yeah, yucky on white.......
I had the ign. module on the pass. fender on the Killer6, oppo the exhaust heat, back in the '80's-'90's it held up but in storage since it melted out all over some other stuff I had saved...good times..
The car had been sitting in a storage unit in Florida for about 14 years when I bought it. No potting left
Lol, some can be in a box on a shelf and bleed out. No need to be on a running vehicle.
I've posted pictures of this one in various stages of its melt down.
This is how it looks now......
Same ECU February 2020......
Probably not....but that looks just like the standoff Honeywell used for their ignition boxes on certain furnaces and most all boilers.... on those, hightened humidity was certain doom.
