STUPID QUESTION!!!!
Yes it makes an engine run hot...can't explain it but I once burnt my fingers on a wing nut of a friends 383 that was running WAY too lean.
Yes LEAN can be very MEAN. Watched my Harley pipes turn blue going around the block once! Another block I would have probably fried a piston, valves or both.
Yup. My 70 Cuda was running lean and always ran about 210. Jetting up helped a bit. then I decided to try some Cam2 (was pinning also) Temp dropped down to around 195.
