Installing a new water pump today on my 71 Duster & would like to do something to reduce corrosion on bolts. When I removed the old waterpump - one bolt was rusted stuck. I think the corrosion was on the bolt above the threads where it passed thru the water pump. Is wheel bearing grease as good as anything on the bolts when I re-install?
