Sun Super Tach II wiring
az426hemi
Mesa, AZ
Anyone know how to wire up a Sun Super Tach II. I have a 63 Dart with 360 and electronic ignition.
Any help will be appreciated.
Thanks,
Mike
Just go to Jeg's or the summit website find your tach and download the install instructions. That's what I did.
The red wire is the hot wire that connects only when the ignition is on. The black wire is the ground. The green wire goes to the negative side of the coil or, if you have an ignition box, the tach port. The white wire is the light and connects usually into the light switch circuit. You could use a toggle switch.
Pat
