pacuda59
pacuda59
I found a super six at a yard yesterday. My question is, do I need the exhaust manifold also?
All the /6 manifolds are the same, the newer ones have more reinforcement in there casting, If you was wondering if a super 6 was different then a non super 6, no difference at all between the two
So I can just as easily drop a two barrel on my current /6 manifold?
Stupid question, but why all the fuss over getting the Super 6 set up from the newer cars?
I just told you, because mating two random manifolds together is a lot tougher than installing a set that's already been matched up together. The exhaust manifolds are all about the same other than the choke pockets and heat risers. The problem comes when you mate two random manifolds together. You either have to take them to a machine shop to get machined flat or get out your long board sander and spend some quality time with the manifolds.
Cause the newer cars are all the super 6 came in. I would get the exhaust manifold too. That way, you can take it home and get it apart. They are all bad about leaking somewhere, whether it's between the intake and exhaust manifolds or elsewhere. Be prepared for a bolt or two to break. They are bad about it. Use lots of PBlaster. But after you get it all fixed up, you'll have a nice complete piece. Good score.
REmember the special 2bbl kickdown, thats worth as much as the intake.
Not sure what you're referring to.
OK...I saw the linkage.....thanks.
Another question, the carb looked every bit it's age with oxidized metal, etc. I'm assuming it will need a rebuild? Is that a job for a pro?
Easy man.....just asking a question.
I wouldn't say pro....but if you 've never done a carburetor, you might consider letting someone do it that knows how. I'll be glad to do it for you probably more reasonable including shipping tham most anyone.
Sorry wasn't trying to sound jumpy, I think I just worded it weird I was just trying to stress that these manifolds are extremely leak prone and only get torqued down about 10ft lbs, so you have to make sure everything is nice and flat before you put them on. There are also good quality gaskets to get such as Remflex and/or the aussie gaskets. You might be able to get away with using a regular parts store gasket but you better make sure everything is perfectly flat.
Yeah SS is correct, make sure you grab every bit of linkage off that thing. People always remove the intake but forget the kickdown linkages and brackets. The cars then get crushed and now were left with a bunch of super sixes with no linkages.
Definitely keep the original carb. If it's not leaking from the throttle shaft and is rebuildable, it'll work way better than any parts store carb you could ever find. They are a little more difficult than your 1bbl to rebuild but they still aren't bad.
Also if your car doesn't have electronic ignition, you may want to grab the distributor out of that car as well if it looks ok. Good original electronic distributors are getting hard to come by.
