i just put a carter bbd on my 225 slant 6 and need to hook up the throttle linkage to the carb. if you have pictures so i can see what to do or any advice on how to do it.
There shouldn't be any throttle linkage on a '67 and newer car.....just throttle "pressure" linkage for the automatic transmission cars. The throttle should be operated by a cable. If you have a '66 and older A-body, you'll need to convert the car to a cable style throttle as the old 1bbl linkage setup won't work with a 2bbl.
