67Signet
Smoke and chaos stunt coordinator
best gas milage being the goal!
Please help!
I have 2 slant motors
I have a 170 (1965 101 H.P) slant 6 in car now with 3 on the tree also have a 225 (1970) block that may have a spun bearing for parts, oh and a super
six set up.
what can I do with these parts?#-o
This would be for my 1967 Signet with a healthy 170 1 barell now.
The block for the 225 may have a spun main bearing "per P.O", I want as much power as I can from the Signet running its 170 the "only good bottom end I have " right now.
(I have another build I am working on and this is to be my gas myzer daily driver)
Should I just install the super six and call it or..
Would it be better to use the 225 head and the super six set up then adding a 2 1/4 exhaust pipe from the manifold?
Should i stay with the stick or use the automatic?
I will be adding an electronic ignition as well.
After Im done with my 360 Dart i will may rebuild the 225 for the Signet.
Im not very familiar with slant six and need help for my daily driver
keeping costs down and gas mileage up!:rock:
thank you to all who add ther .02 cents here.
Or do you see a better option here please let me know
I also have a 273 2 barell with trans but I just want the best driver with the best possible gas milage.
Thank you
Bruce B.
Please help!
six set up.
Thank you
Bruce B.
