Super Stock Dash:
3DARTDAVE
Tulsa, Ok
What was was the dash look like around the defrost and blower switches.
As well as the radio delete plate.
Here you go...
Dart or Barracuda?
For Dart it is one different plastic casted fascia piece with all 3 items blocked off
For Barracuda, there are 3 plastic block off plates for inserts.
where did you get that radio/heater delete panel? I just ordered one that said it had both delete panels in one, it came with the radio slots but the heater panel was solid.
you got a heater delete but WITH radio plate.
you need a heater delete AND radio “delete” fascia/plate.
you can make with with textured plastic sheet to cover the heater controls. Then glue plastic plug for the radio holes and the modeling putty to smooth things out. Also sand off the outward ledges around the radio cutouts.
the one I pictured was hand made by NS1RM21.
it’s like building a plastic car model
