Super Stock Springs ( US or Mexican )
NCmtnDWELLER
Cartoogechaye - NC
Other than we all prefer USA made
( Older USA ) made are their and true differences in quality or performance between the two ?
Thanks Chris
I have the xhd mopar a springs made in Mexico. I bought these like 10 years back. Still have the same tight feel and the rear is not sagging at all. So I say mexican made springs are well made.
It was a bad batch of sprAng steel that got the bad rap. It couldda been anywhere, but it happened to be Mexico. Mancini sells their version, but I don't know where they're made. You might call and see. They're kinda funny though. It ain't like talkin to somebody south of the Mason Dixon line. You'll see.
I've got a pair of original SS springs that the leaf's are noticeably thicker, I've had them for fifteen years and never checked the parts numbers. I personally should and see if they belong to somthing special.
That's a hefty question that needs lots of research or multiple congruent first hand experiences to make a determination.
Example: Chinese Craftsman wrenches. Many people say they're the same and work great. How do we define that they work great? Usually, 'it removed the fastener' is all people are looking for a a qualifier.
Hell, by the same standard, an oxygen acetylene torch is a great wrench, and people don't look at factors like: Did the wrench damage the nut, did the wrench remove x number of fasteners before it wore appreciably, did the wrench fit in the same locations as its American predecessor, did the wrench apply maximum torque before failing, did the wrench resist corrosion accordingly, and so on and so forth.
I can tell you that the wall thickness on a Chinese Craftsman wrench is much thicker than its American forefather. Why? The material is lower quality so they needed more of it. I can also tell you that the Chinese wrench will bend far more easily because the material is either softer/ weaker or because it wasn't heat treated properly and this leads to greater wear on the wrench when used on harder fasteners. The wrench isn't sized right, and therefore grabs the corners of the fastener instead of the flanks, so on and blahblahblah.
The SS springs can't simply be measured to be a different thickness and that's all she wrote. The material, heat treat, life cycle, etc all factor into it.
I don't know the answer, but take the above into account in your answer.
Also, how can I tell what's under my car? I have two of the same spring per the Mopar Action green brick build. I need to get them lowered but haven't researched the right way to do that.
Also, add in:
These cars are 45-60 years old. So a replacement spring.... any spring is typically better than the 50 year old spring that’s worn out. “WILL the new spring hold up areas of a car for another 50 years?” Not sure as I’m not going to be around to find out.
SN: Harbor freight Chinese stuff seems better than the new Chinese stuff from “Craftsman.”
I cant speak to Made in Mexico leaf springs but in general as far as stuff made TODAY or in recent years, I think Mexican made parts are at bare minimum equal to current made in USA stuff. A big part of that is the fact that it is so close and American companies can have much more control over the level of quality being delivered. As a machinist, most of my best new hand files in the past 10 years have all been made in Mexico and easily outperform files made in other countries. Many of my replacement car parts for my daily drivers come from Mexico as well and they usually have a noticeable quality bump over their Asian counterparts
For years Mexico has been making or rebuilding car parts and have been doing good quality parts. Its like everything there will be bad parts in any country. With the exception of Taiwan. For years there products were terrible to be honest. Lately I don't know.
Remember those Taiwan socket sets you could buy in the early 80's for $3.99 , the sockets either stripped or split.
crap' wrenches'.....Taiwan or.....India? Seen ghastly chunks of scrap metal both have called 'wrenches' in different toolboxes. My favorite was a wrench made in India that had a casting line right through the center and the 5/8 open end would not even slide onto a 5/8 nut because the casting flash was still there.
I remember my dad a mechanic bought a set of wrenches made in India while not too terrible they would crack if put to heavy use as like in the normal use in his auto shop. So he went on to replace that wrench set for some Matco wrenches. Those held up just fine.
