Sure Grip issues
A few decades ago, I made the rounds and collected a pile of suregrips from local picNpulls. From the gleaned parts, I rebuilt several of those banged out cases;
I took them to my favorite local machine shop, who fixed the saddles up stronger than new. The cases were no longer a problem.
Finding good used guts, was.
After I cleaned up the cones, I restored the clearances with shims as was required, reset the cone-preloads to suit my combos. and then I stuck the reconditioned cases into various chunks from 2.76s to 4.30s, and from there into my cars, some of which were from 330 to 430 hp, and ran the crap out of them.
Some say that they are not rebuildable. ......... IDK what that's about. We recondition/rebuild 50/60/and 70 year old engines, transmissions , and carbs don't we? Com'on, compared to those, rearends are nothing.
I might still have one or two kicking around. Since yur practically next door, ............
I have spoken to a local recommended shop (Vogt Automotive) and they said they could rebuild the diff. If I run into any parts difficulties, I will gladly let you know!
The cone types by design wear into the cases.. Can you shim and make em work, sure. Can you make them good as new... Well, that's very subjective. Once the pins eat up the case halves is it really cost effective to stay with the 2 pinion gear vs upgrading to the 4 pinion powr lok? Only you can decide that. If it was my $'s I'd find a good used powr lok and replace the clutches, short of catastrophic failure they are 100% rebuildable. I'd take strength and longevity over it'll sorta work and might hold up any day.
Is this what I need? I'm out of my comfort zone when it comes to diffs. I'm up in Saskatchewan, so no Dr. Diff locations up here.
1pc Powr-Lok Sure-Grip Posi - Power Lock For Chrysler 8-3/4 - 8.75" - 30 Spline | eBay
A little late with my response, but here goes....
The chinese eBay versions are a crapshoot. You might get a good one, machined properly, you might not. I believe factory tolerance for runout of the ring (crown) gear is half a thousanth. Four thousandths has been reported for the chinese ones . Makes gear setup difficult, possibility of noise more likely.
Now, to be honest, I've got a 741 case 3.55 open, and I AM considering trying one of the eBay versions. I will LIKELY spring for Dr Diffs version.
I called a local speed shop with an excellent reputation here in Regina and will be dropping everything off this week. I will trust them to make the right call. Want to go with the clutch disc type for reliability.
I had one of those Ebay clutch dana jobs for a few days. Steer clear. Cross pins and ramps were machined wonky, you can even see it in the pictures if you look closely.
I have had good luck with the ones I have used. I mostly use old Dana Powrlok and renew them. But have gotten some eBay I ones when they first showed up on market before Dr. Diff stared getting them and going threw them. I would if in market get one from him instead if an orginal can't be sorced and rebuilt.
I have one eBay special 2-3 years ago I got in a parts deal. At this point that has been moved around the garage to many times that the plan is now to add it to a spare 276:1 with new bearings and races while apart to freshen. Versus leaving it a one legged pirate.
I do know I don't like the bolts they used to bolt the halves together. Just look cheap, but that's just because their cheap. The others I had were fine. But who knows the newer ones maybe crap.
I can get pictures of it if interested.
They are rebuildable just not as easily as replacing a set of clutch disk and plates.
Rebuildable and repairable are not the same thing. You can repair a cone type by milling down the sides of the cones and shimming the springs up (as long as the spider gears, case and cross shaft are ok) but the cone faces will still be worn. Nothing you can do about that
Yeah let's see it
Yeah let's see it
Here ya go
I agree the bolts look cheap even though the markings on mine indicated they're metric/chinese etc. grade 8 equivalent.
I would be suspect on that as some metric fasteners are smaller for an equivalent SAE size. They MIGHT be just as strong (or stronger if engineered correctly) I'm no metric bolt expert
Here is my reason for not wanting a cone style sure grip... They start eating themself on day 1... The cones eat into the case chewing up the case as well as the cones... Yes, the small end of the cone can be machined off allowing it to grab and eat some more... When you do that you need to shim the side gears to reduce the backlash... This was ever the intent of the engineer who designed it but mechanical people are crafty and found a way to prolong the life of the cone style units... But in spite of being "Rebuilt" the unit is still eating itself and while eating itself it is putting metal filings into the lube.... Which in turn means there is metal going through the bearings and gear teeth...
Also as the cones & case are eaten the backlash on the spider gears is increasing...
A clutch style unit eats the clutches... Which are made of a fiber material... It doesn't effect the bearings or gears... When the clutches wear out you can replace the clutches, they were originally sold by Chrysler & now are available through the aftermarket...
Just came back from the speed shop doing my 8 3/4 diff overhaul. Took some pics of his funny car! Amazing! He will fill and redrill the axle flanges and upgrade the studs to 1/2 inch to give me more wheel options and modify my existing drums to fit. My old rally 14 inch wheels won't fit, so I'll have to move up the wheel and tire purchase. here's a pic of the car they are campaigning. It's waiting on the hoist for an even bigger engine!
I rebuilt several cone clutch sure grips years ago. I'd get a machine shop to take 0.100" off the outer ends of the cones, then make round donut shaped shim washers from thin metal to space the spider gears back into full engagement. Always worked great.
The shop reccommended and ordered in a clutch type. don't remember the name.
Tell me more. A few days looking at it or running it?
Tia
Just looking at it, trying to convince myself it's alright. I couldn't do it. The way it was machined had the edge of the cross digging into the ramps. Looking at both sides they're off the same direction. You might get a better one than I did. Temu had them for $90 if I recall.
Exactly. The angles machined into the carrier and/or pinion cross aren't a \ \_/ / with equal opposite angles. Might be okay but I didn't feel good about it
Any idea if that's the way the OEM parts are?
Unfortunately no, but the FSM shows how to measure ramp clearance with them being parallel in an illustration. And mine had zero clearance on one side and that's definitely out of spec. Might make a difference, might not.
I tend to overthink these things.
Zero clearance is normal, the spider cross can move... when it moves it will try to climb the ramps... When it climbs the ramp it loads the clutches.... cornering if you are off the gas the spiders are free to rotate, hit the throttle, put some torque through the thing & the clutches hook up...
The ramp angles should match, but I've seen plenty of originals that didn't... Ideal? No, will it still work? Yes...
