dana type limited slip uses two spacers and a pin in the center of the diff to hold the axles apart , and it can't be adjusted enough to get rid of end play .
There was nothing I said that was "wrong". Ask zigs how I described it in a PM. You MUST get all the free play on the passenger's side first. Which is what I told him. So, point out in my post where there was a mistake. There was none.
You said I was wrong! I just said end play should be the same on both sides
That's correct. But you said nothing about getting all of the end play to one side FIRST. If you do not do that, your end result will not be correct. Leaving that info out, made you wrong, since leaving out that step will give the wrong result. Now, where was I wrong? Just because I said you were wrong?
Post #2 already said read the FSM, post #3 said Pass end play set, So if he did it right the drivers side will be the same, that's what I was referring to in post #4.
It will not be the same unless he taps the driver's side axle in FIRST to get all of the end play on the passenger's side, where the adjuster is.
Regardless, all this may be a moot point, IF ha has a Dana Power lock as he has hinted to, OR he has green bearings or both.
If you taps the drivers axle in it will take the play out of the pass bearing and will put all the play on the drivers side.
I just tighten the adjuster down so there is no play on ether side and loosen it up so there is a little play, it's done.
Looks to me if you drive the drivers side in you just took all the play out of the drivers side.
Then you can adjust the passenger side and be done with it.
I say
Oatmeal
Rusty's PM to me was by the book and no need to argue , not worth it.There was nothing I said that was "wrong". Ask zigs how I described it in a PM. You MUST get all the free play on the passenger's side first. Which is what I told him. So, point out in my post where there was a mistake. There was none.
Clutch 8 3/4 powr-lok as by Dr Diff. The bearings were on the axles when I pulled them for the swap. this is compete new stuff no used parts other then bearings shown and no thrust buttonsWell, them ain't green bearings. lol Now, is this a clutch style Dana Powerlock unit?
That exactly what the FSM article says that HE posted HIMSELF. LOL
