[WANTED] Suregrip cone style parts
Here is a few pictures. Of what I need. Thanks
Do you know which open unit. I tried one out of a 741 unit. It was to long.
I've done it 4-5 times and never looked at what case I took it out of. Everyone I used was a tad bit shorter than the original. I have also drilled the opposite side of the case to install the small pin that keeps the cross shaft in place. Also the original pin is 1" by .250 in diameter. Go to your local bearing supply and get one 1 1/4" long by .250 in diameter. The factory one is really to short to begin with.
I have a good unit that the pinion came back against. The yoke came loose and the pinion put marks in the outside but it is still usable as is. $100 plus shipping for the whole unit with the races on the same bearings they came off of .
