1969 barracuda fast back 340 /auto/rebuilt 4612sa avs carb
suddenly started to surge while cruising at 55mph//never had this problem//with a 1yr old rebuilt carb
mash the throttle//no response !! but will hold 55mph
fuel pump measures 4/5 psi how ever hard to measure flow
cut fuel filter open // some what clean//replaced still have issue
will take carb apart to recheck everything
have new //sending unit sock/retainer wrench/gasket //tank to filler neck seal//
any help??
can you drop the tank without taking the fill neck/rear seat/ seat pan// out ??
any help??
