[SOLD] Suspension Parts from my Demon Build
dale_brennon
Louisville, KY
I have a few different setups that I had picked up from the time I spent doing my Demon build, but I am selling the car so the parts must go as well. The parts are all located just North of Houston, TX. I am willing to meet somewhere that is within reason, or I can ship the parts. I can't upload pictures right now for some reason, but I will try to fix the issue and post pictures as soon as I can. For now you can PM me and I can send you the picture that way. Sorry for the technical issues.
RMS Tubular Control Arms- $290.00
RMS Adjustable Strut Arms- $190.00
QA1 Coil-over Springs- $40.00
QA1 Double Adjustable Coil-overs- $225.00
BBP Front-end Brake Conversion- $350.00 (No rotors)
BBP Front-end Brake Conversion- $450.00 (Rotors included. This is a brand new setup all parts still in sealed bags)
8.75 Rear-end completely built and ready to be installed. It is a BBP drum set-up, with a brand new 3.91 Richmond gear setup installed. The spring mounts have been moved in for the SS set up. Also comes with SS springs, and the relocation mounts from PST to move the mounting location on your car. Asking $1300.00 for the entire setup.
Here are the pictures of all the parts. Also I forgot to add that I have a set of Subframe connectors from Mancini Racing that can be either bolted or welded in. I also have a roll-cage for the car as well, that was never installed it was bent, just needs to be fitted, and trimmed.
Subframe Connectors- $125.00
Roll-cage- $275.00
