Swapping 1964 plymouth Vailant from automatic to 4 speed
64whiteghost
Whats up guys. thank you for all the help you have given me.
So my car originally is a push button automatic. Will I need to swap the transmission crossmember ? If so is there is a dual exhaust version that I can install to allow the exhaust pipes to flow tighter to the body ?
Sweet !!! thank you !
Yea Im running long tube headers so I will need that mod.
No questions on the rest of the things you have to do with that changeover?
No. I already figured out everything else. Been researching and called Brewers to guide me on the type of bell housing and parts i need to convert it.
What are your suggestions ?
I assume Brewers has given you what you need to know whether you use stock '64-6 parts, or, convert to the '67-up stuff. It's possible that your crank isn't machined for a stock pilot bushing, but, that will depend on the crank used. If it's a 273 forged crank from an automatic, you'll need to either drill the hole to the correct size, or, hone it smooth and cut down a bushing to fit. If it's a 318/340/360 crank that isn't machined for a pilot bushing, just use a Magnum pilot BEARING. Naturally, you'll have some floor/hump work to do. Have fun!
@cudamark
Here's a question that may help both the OP and myself, as I'm swapping my 65 Barracuda to a 4 speed. If an Early A came with an automatic, does it have a hole for a clutch rod already there like the later A bodies? All the later ones came with the hole, which has a plastic plug in it if the car has an automatic. My Barracuda's engine bay is still greasy and grimy, and I haven't noticed a plugged hole for the clutch rod.....but it may be under the muck.
Be aware that Dart and Valiant are 2 different wheelbases so the Dart driveshaft is longer than a Valiant.
That will depend on the years and models involved, and how they're equipped. It has to do with the length. A '66 Dart S.W. for instance uses the same driveshaft as some '66 Valiants/Barracudas. It's just a matter of length.
Yes I should have included that all north American Abody wagons are on 106-inch wheelbase also Canadian cars are on 111-inch wheelbases except wagons which are 106 inch. I believe the original post was for 63-66 early A bodies.
