straightlinespeed
Sometimes I pretend to be normal
I have 73 and up Disc's on my 71 Scamp. I want to add a sway bar to my car and I have a 70 LCA now. Will the lower control arms swap over ok or do I have to find 73 up LCA's?
If you still have the '71 K frame then the '70 LCA's will work just fine with a '67-'72 sway bar. The '73+ sway bar will only work with a '73+ K frame and LCA's.
the only diff is the tab location.you can always but the tabs and weld them on yourself.
Do you have a source for the tabs? Im not aware of any place that sells them.
Most aftermarket sway bars will come with the necessary tabs, or at least the tabs are available with them. If you're looking for a stock sway bar, then you'll have to add them yourself. But, they're super easy. If you can weld, then you can make these tabs.
Not my pictures, I borrowed them from another thread on here I think...
Those measurements won't help him since he can't used the 73 up sway bar with the 72 back K frame.
