[WANTED] Sway bar brackets
killerslant
Gobles, Michigan
Looking for a pair or even a single sway bar mounting bracket for the 67 to 72 style sway bar. I think b bodies are the same.
If you can't find them Energy Suspension makes a 4 bolt bracket that uses the original holes and adds to them
Actually that's what I am taking off. Found an original. 990 sway bar and going to put it with my 383 K frame.
Sacrifice the bushings. I have drilled them enough to get the bar greased up and pulles through. The hard part is putting new bushings in.
