sway bar set up
moparwedden
trenton,ontario,canada
When I Install My Front Set Up Will It Be Better If I Am Having The Front Tires Sitting On The Ground Or Will It Work If The Car Is In The Air.
In the air,snug up your links drop down and snug some more,in the air you will be able to slide your bar side to side to line things up.Whatsss ya working on?
Personally,I think it,s easier to install the pins and bushings while on the ground.Then crank them tight.JMO.
You could always lift the car on stands,then use your floor jack to lift one side at a time to do the pins and bushings.Again JMO.Good luck and say hi to Snakeskin!LOL:toothy10:
