sway bar?
caw440
I have a 69 Dart 6 cyl. I'm going to a 74 scamp K member and a 360. I 'm going to order a front sway bar for this car, do I order it for a 74 or a 69 Dart?
Definitely for the 74. The 74 goes through the K-frame while 72 and older goes across the front. However, you'll need to tell whoever you're buying from whether you are using LCA that have sway bar tabs, or if not. Typically aftermarket sway bar tabs bolt to the lower shock mount. The OEM mounts are about 1½" closer toward the center of the car. The factory fit bar will not work with typical bolt-on sway bar tabs.
Thanks for info everyone I really appreciate it.
