Map63Vette
For all T56 swap owners out there, how many of you have a true Viper trans in their car (not just a Viper spec trans)? What did you do about a connector for the speed sensor? I have a true Viper T56 (from a 2000 year car), and Dodge used a hall style 3 wire sensor for the VSS as opposed to the single wire GM style. Has anyone retained the stock VSS and if so where did you get a connector to match the factory plug? It looks like a Metri-Pak of some variety, but I've had no luck sourcing it and don't feel like buying a $100 harness to clip one plug off of it. Worst case I'll just cut the factory plug off and wire up my own 3 pin connector, but if possibly I'd rather just use what's already there.
