hi,
my tachometer doesn't work. i have an 66 barracuda formula s. the wireing under the dash is original.
my sending unit is also original. i bought the car some months ago. the preowner has installed a customized dash with autometer instrument. now i converted the dash to stock but the tachometer doesn't work. i measure on the sender that on the yellow cabel that goes to the tachomter had only 0.4V. if i turn the engien higher it stills stay by 0.4V. the voltage should go up.
i think that something wrong with the sender. i will try to put 1V - 4V directly to the tachometer to look if its work. i a right?
were can i find a circuit diagram of the stock sender? so i can check the electronic.
the preowner has build in a 360 engine with the orange mopar ecu. does the old sender work with this electronic ignition?
i know the RT-eng reproduction board...and maybe will be buying them. but want to know why it doesn't work.
thanks
thanks
