ramenth
Gratis persona
Jamison has a small hairline crack in the edge of one of of his tail lights. Anyone have a good fix for repairing a crack in transparent plastic?
With the flat surface is there any interest in replacing all the lens with home-built ?
I have used super glue to repair all the broken studs on my GTX grill and any other broken posts. I then would finish with some epoxy around it to really secure it. The epoxy wouldn't work on the outside but you could put some on the back side to help stiffen it up.
But to answer your question Robert, yes the super glue works but be careful around the red lense(I see you have it taped)so as not to haze it.
Eastwood makes a lense repair kit for the actual colored lenses. I have not tried it but am intrigued.
Is the crack all the way through?
