diymirage
HP@idle > hondaHP@redline
im getting somewhere with my lean too, and one of the things i want to do is put a rope and pulley system on the rafters so i can take the top off my bronco by myself (like the old block and tackle systems you would see on sailboats)
so, my main idea is to put 4 pulleys in the rafters (one on each corner of the top) and run a rope through them, down the to top, to a hook with a pulley, and back up
now, if i run a single rope through the whole thing i will had a reduction rate of 4, but if i run two ropes, i will have a reduction rate of only 2
my main concern on the single rope setup would be that it would not lift evenly
any thoughts on this?
