Tanks, Inc Venting
So you are only using the fuel filler vent?
Yes. You can't get the supplied rollover vent high enough, even in the wheelwell, unless you vent it in the cab(that wasn't acceptable to me). I have both of vents plugged, the pump vent and the tank vent. Only using the original filler vent tube. Goes higher than the fill tube and vents under the car. It's perfectly acceptable.
