tanis4457
Does anyone know if there has been any tests done of Holley Sniper or Fitech TBI EFI units on dual plane vs single plane manifolds and the pros/cons? Porting vs non-porting for a TBI EFI intake manifold?
I'm going to be installing my Holley Sniper EFI system onto my LA360 motor and I'm wondering if I should go with a Air Gap RPM or possibly a single plane intake. Since the TBI EFI and carbs are both wet flow type systems, is the same principles the same regardless of carb vs efi? Dual plane for torque and single plane for higher rpm's. I've also heard it's better for EFI to port the heads and intake to have smooth runners and to get rid of rough edges.
