Temp sensor size?
Speaking of aftermarket gauges.........where is a good spot on the firewall ('69 Dart) to punch through for lines or are there
some existing holes that would work?
Thanks
The insulation pad plastic holders work if there's one near the left side not blocked by the heater box. The knockout for the clutch linkage works if you have an automatic.
Thanks
On my 73 there is a hole near the master cylinder. I’m running my tac and gauge wires through there.
