The regulator is plugged in with the 3 heavy male spade terminals on it but...
Theres a little round part called noise suppression capasitor that also has a spade terminal on a short length of wire. This one is plugged into the same center of 3 female slots with the regulator. So... Reach under there and pull the regulator, the lead from noise cap may stay in place or it may come out. If it comes out and not put back where it goes you could have a pop noise in the radio speaker. More importantly, A loose/intermittent connection since that female has been stretched to fit 2 males. Those are special fancy springy female terminals sort of like whats in a wall outlet. They widen tolerances in limiter construction/male fitment, absorb vibration, etc... The weight of the limiter would probably crack rigid solder connections over time. Too much info I'm sure. Anyway... Some owners have successfully exchanged that limiter laying upside down in the seat, whatever. Others pull the inst' panel to geter done. Then there are those who pull the panel and replace the OEM mechanical limiter with a solid state regulator. Good luck however you proceed.
