'The 383' ~ Getting Those True Factory Horsepower Ratings
Mopar 383 ~ 4-Barrel
With Timing Set @ 35* Total Advance
Year ............ Advertised HP ............... True Factory HP
1963 .................. 383 ~ 330 HP .................... 285 HP
1964 .................. 383 ~ 330 HP .................... 285 HP
1965 .................. 383 ~ 330 HP .................... 285 HP
1966 .................. 383 ~ 325 HP .................... 278 HP
1967 .................. 383 ~ 325 HP .................... 278 HP
1967 .................. 383 ~ 280 HP {A-Body} ...... 271 HP
1968 .................. 383 ~ 330 HP ..................... 288 HP
1968 .................. 383 ~ 300 HP {A-Body} ...... 283 HP
1968 .................. 383 ~ 335 HP ..................... 303 HP > {Road Runner / Super Bee}
1969 ................. 383 ~ 330 HP ..................... 288 HP
1969 ................. 383 ~ 330 HP {A-Body} ...... 295 HP
1969 ................. 383 ~ 335 HP ..................... 303 HP > {Road Runner / Super Bee}
1970 ................. 383 ~ 330 HP .................... 288 HP
1970 ................. 383 ~ 335 HP .................... 303 HP > {Road Runner / Super Bee}
1971 ................. 383 ~ 300 HP ..................... 299 HP > {w/Holley Carburetor}
~ The Magical 1962 - 383/343 HP 'Dual-Quad'
Yes, that was the 'best one'.
That was a very good night at 100 degrees.
Yes,it was... We ( car club) gave some soul &sweat here.... It took a lot of " the before night ' hustling , to make it work... I dead lifted the pig in, I miss that stuff'...
Hey Noonan,
If you look up the 1969 Mopar 'Package Stock Option', you will find the
details on the 383 Performance Items.
Mike,
The 1969 Road Runner 'Convertible' 383/335 HP was heavy enough
{#3574 lbs.} to get into the {10.50 to 10.99 Wt/HP} NHRA Class.
'The Package Stock Option'
Included;
* Camshaft {Part #3412004} ~ {.484" Lift ~ 284* Duration ~ 68* Overlap}
* Matched Lifters
* Edelbrock DP-4B Aluminum Intake Manifold {Part #2836149}
* Holley #3310-1 {780 CFM Carburetor} {Part #2836172}
* Air-Cleaner Mounting Base
* Hooker Headers ~ 1 3/4" Primary ~ 42" Tube Length ~ Collector Outlet 3"
According to the Mopar Performance Guide, this package would add {+50 HP}
to the 383, and would knock {4/10's} off your Elapsed Time {with Closed Headers}.
Bean Man,
Here is what Plymouth posted in November 1967.
1968 Plymouth Road Runner '383' {Coupe}
* 4-Speed {Inland Shifter}
* 3.55 Gears 'Sure-Grip'
* F70 x 14" Tires
Best Performance ......... 14.74 @ 97.60 MPH
Performance Upgrades
* 26" Heavy-Duty Radiator
* Viscous Fan-Drive
* Fan Shroud
* Dual-Point Distributor
* Champion J-10Y Spark Plugs
* High-Performance Ignition Wiring
* Accel Hi-Performance Coil
* Performance 'Advanced' Timing
* 3.91 Gears
* Hurst 'Competition/Plus' Shifter
Best Performance ......... 14.29 @ 99.07 MPH
Bolt-On Goodies
* Edelbrock DP-4B Aluminum Dual-Plane High-Rise Intake
* Holley #3310-1 {780 CFM} Carburetor
* Casler 7" Wide x 27" Tall Slicks
* Adjustable Pinion-Snubber
Best Performance ......... 13.98 @ 101.49 MPH
Performance Add-On's
* Holley High-Pressure Fuel Pump
* Hooker Headers {1 3/4" Primary x 42" Tube-Length x 3" Collector Outlet}
Best Performance ......... 13.75 @ 103.88 MPH
Camshaft Swap-Out
* 'Hydraulic' {.484" Lift ~ 284* Duration ~ 68* Overlap}
* Matched Lifters {-.0005" under-size ~ 'Low-Friction'}
* Double-Roller Timing Chain
Best Performance ......... 13.60 @ 105.50 MPH
