T67POWER
- Joined
- Sep 30, 2009
- Messages
- 669
- Reaction score
- 9
Small blocks use a positive seal on the intake valve and a umbrella seal on the exhaust valve.
I was wondering if anyone has used the positive seals on the exhaust valves?
I used positive seals on my 360 after cutting the guides with no problems.
On my 318 that i just bought, i was thinking of cutting the heads for more compression ,bowl blending them and lapping the valves in.
I will clean the heads and check them for cracks.
The valve guides are most likely a little worn but still serviceable.
I was thinking of running all positive viton valve seals on the heads for better OIL CONTROL.
Has anyone hear done this and how has it worked out for you????
THE BUDGET CYLINDER HEAD BOOGIE :-\"
