The right 2 barrel carburetor for a Super six set-up
Mopar King
Beginner / Need of Help
New York
Good Evening Everyone, I am having a problem in picking a 2 barrel Carburetor for my Super six Set-up. Summit has around 10 different 2 barrel Carburetors for different prices. was wondering if there is a difference in them than just the part numbers. Also will I have to get a Thinker carb base gasket as well? will I have any problems with the carburetors like what it says in the Slant six Article. Thanks everyone and Good Nite :color:
http://www.summitracing.com/search/Part-Type/Carburetors/Make/PLYMOUTH/Model/SCAMP/Number-of-Barrels/2/?Ns=Price|Desc
http://www.slantsix.org/articles/supersix/article.htm
With the use of adaptor plate, the holley 350cfm with matching chrysler throttle braket works good on stock or hoped up, but once you go above 260* camshaft, the 390 4 barrel is the better choice to feed the higher rpms
jmo
ditto, that is what I have with adapter plate, although the OEM 2bbl intake has a Stromberg-esqu bore spacing which is a little off for a holley 2300 but the adapter seems to line up correctly.
