JR
Pissed off senior member.
I got 2 carbs at the local pull-a-part for pretty cheap one is a Thermoquad off a 83 360 cube van with no emissions stuff. The number off the base are 9379 S and below that there is 339 3. On the top the number is 2652.
Anyone know what the cfm range is on this carb? I gave it a gas bath and it cleanned up really good and looks like it may have been rebuilt but I will get a kit for it anyways.
The other car I got is a carter 2bbl off a D100 with a smallblock (not sure what year it was, late 70's more than likely). The only numbers on the carb are 2125 and 2028. Any info on this one so I can get a rebuild kit for it? It has a fitting on the top that was hooked to the pcv valve.
