Hey there,
I couldn't find any good advice, hope you can help me.
Bought a rebuilt TQ for 1980 truck 318 application.
Problem is it leaks from the top gasket right above the phenolic body. Leaks are all around on either side, even from stem for acc. pump.
I use a stock-style SB mechanical pump, pressure seems OK (used an old meter to check pressure).
All capped connections according to Vaanth guide...
Hope you have some hints for me.
