RussellSullivan
Trying to figure out a solution to the throttle/kickdown linkage issue that I'll be facing soon (hopefully). I'm going from a single barrel slant six to small block with thermoquad.
I have seen the expensive Lokar cable kit to solve the two barrel linkage to thermoquad problem. From what I understand, the two barrel linkage is not wide enough for the larger thermoquad. I've also seen people bend the brackets to make the stock linkage work.
Does the single barrel Holley 1945/1920 linkage pose the same issue when going to a Thermoquad? I would assume that it does, but then I remembered how far the intake and carb stick out on a slant six.
Just wondering if anyone has done this.
I do have two barrel linkage if I can use it in any way.
