Thin head gaskets?
The last 318 head gaskets I bought ( haven't used yet) are marine ones. I have a couple of sets, one set definitely going into my 78 fury when I do the top end swap (don't want to hear it, as far as heads// I'm using what I have in a cruiser that will never see a dragstrip// you can probably guess what they are).
The other set I hope I can use on the 360 mag that I'm building for my tow rig
The dude that wrote this description needs some education on where to put decimal points.
.28 head gasket would be over a 1/4 inch!
You'd have about 5.75 to one compression with these!
I’ve been using the Mr Gasket head gaskets in my 440s since my supply of OEM steel head gaskets ran out. One of the 440s is 12.5 - 1 cr with iron heads and 650 hp, in thirty five years I’ve never had an issue with head gaskets…
