I am currently installing an alum one in my Newport 383. It says "Pro Cool" and was only $80 new on ebay a few years ago, but probably a special deal. It is pretty thick, I think I see 3 rows. It is all aluminum with welded side reservoirs. It has an 18"H x 22"W core and would fit my 65 Dart if I cut off the frame rail lip on both sides, but should fit 67+ A-bodies with no cutting since wider. Instead of the typical side mounting flange, it has threaded studs in the reservoirs, so you bolt thru the front rad support into it. The lower hose is driver side and upper hose halfway to passenger side, so would fit a SB with older cast-iron pump. The upper hose position avoids my AC compressor. I have room for the fan clutch and am affixing a shroud from an 80's New Yorker. No transmission cooler, but I prefer an external cooler anyway.
