This should be pretty simple: Decal question.
cruiser
Bloomington, MN
The paper tire pressure decal on the driver's door jamb of my 1974 slant six Duster is a really crappy repop. Every time it gets wet it deteriorates some more. Does anyone know if somebody repops these decals in vinyl? I've had excellent luck with vinyl decals but can't seem to find this decal in vinyl anywhere. Thanks!
You could always run the decals thru one of those laminating machines but it would require trimming the decal out close to the edges so you could peel it apart from the backing paper.
Try ECS. All of their products are top notch. I selected 71 A body since they didn't list a 74.
In the same boat. I put the repo tire pressure decal on mine about 15 years ago and there barely any font left on it. Made for a sticker book, not a door jam that gets the occasional moisture on it. Clearly the volumes are there to justify making a small run of stickers for the 74+ A bodies. I’ve got the same issue with the engine emissions sticker too (Phoenix even confirmed that).
